Results 1 to 10 of 14
Thread: Spark plug help
    Default Spark plug help
    I have here a picture of one spark plug I pulled out. This is the worst one out of the bunch but they are all generally in the same condition. A little oily around the threads and a little carbon built up. The electrodes are still present ... Is this normal for a motor with 800hrs? Or is this indicative of a more serious issue (I:E top end needing rebuild or needing valve job)? And what spark plugs are you guys running? Boat stays between 2000 feet to 6000 feet (if it matters)
    What year and engine do you have?
    To be safe, check your compression on all cylinders.
    Call SKIDIM with your year and motor size. I think I noticed this yesterday on Facebook, 454 correct?
    Apr 2009
    SE MICHIGAN
    run a r45ts ac delco or if you want to spend more money mr45ts
    are you running points any coil up grade ?
    buy the looks getting the right plugs will clear up your carbon issue
    1986 TSM6
    1987 SALTERA
    1990 454 pcm
    Quote Originally Posted by angus2112 View Post
    Yes msd ignition, blaster ect.
    Yes on the supra page.
    Not a fan of MSD ignition definitely not a fan of the butt connectors on the red and black wires. The correct plug is a AC MR43T. The MR45T will run a little hotter.
    I agree , previous owner installed MSD. And did the connectors. I'm contemplating buying a new motor or even crate motor or trying figure out pricing for a new rebuild. (Change to roller cams and new top end) but want to ensure the pistons and bottom end are good before I do all that.
