1994 Supra Sunsport Blower Switch - replacement
1994 Supra Sunsport blower switch question... My blower switch seems to be failing. One of the 2 blower motors is working and the other is not when I flip the switch. The switch has 2 circuits coming into it and 2 circuits going out of it (2 blower motors on their own circuits with a single switch controlling both at the same time) which means DPDT, right? Anyway, if I switch the outgoing wires, then my other blower motor works so I think the switch is bad. My confusion is that I think I need a DPDT switch that is ON-OFF. However, the only DPDT switches I can find are ON-OFF-ON. What am I missing? The blowers are either ON or OFF and when ON then both blower motors need to run and when OFF both blower motors need to be OFF. Any suggestions of where to get the right kind of switch? I've looked at these:
https://www.delcity.net/store/Illumi...2.h_788921.t_1
https://www.go2marine.com/Blue-Sea-7...tch-DPDT-Black
Yes. I couldn't find that they had much for switches. I saw that they were recommended in the past but maybe they don't currently supply switches like they used to.
