Results 1 to 10 of 15
    Jun 2020
    Default 1986 supra 351W BAD miss under load after warm up
    so ive pretty much had this problem for a year now. Once the boat warms up if i put a heavy load it starts to miss really bad but it will kinda clear up after i cruise under little load. yesterday i adjusted the timing and did like 20 out the hole digs and it ran great and only had a very small slight miss so i thought i had it. Here are the things ive done
    New cap and rotor
    new spark plugs
    chaeck timing around 6-8 degs
    new water separator filteri have a mallory electric ignition and distributor
    also what are the best spark plug wires
    thanks
    N.W. Suburbs Chicago, IL
    Check your ignition coil, mine went bad and I spent a significant amount of time chasing all sorts of issues that resolved with the new coil.
    Riding Connelly Skis
    Are you still running points?
    Jun 2020
    No it’s all electronic
    Good place to start. Also, has the carburetor ever been rebuilt?
    Jun 2020
    Carb is new just picked up a coil and a fuel pressure gauge bout to slap that on there. What about plug wires what are best?
    Quote Originally Posted by bonomosupra View Post
    I used the standard PCM wires all the years I had my 89'. Never had an issue. On my current boat, I bought a set of Standard Blue streak ignition wires from Rock Auto. These were a step up from the stock Indmar wires.
    Jun 2020
    Can you get them from a auto parts store? If so do you have a vehicle to reference for them?
    I donít have the info anymore on my 89í. My 2004 takes different wires.
    What electronic ignition brand are you running ? Some of the electronic conversion system were problematic.
