Results 1 to 6 of 6
Thread: Perko switch
    Aug 2018
    Default Perko switch
    So we bought a 2008 Sunsport 22v and evidently itís had several different amps in it. It currently has pro 60s(trashed surrounds) on the tower, kicker in boats and 2 kicker 10Ē 4 ohm subs. The in boats are driven off the head unit and the tower and subs are driven off a single jbl ma704!!!! We have a kicker non marine 500x1 amp weíre going to put on the subs and will drive the tower off the jbl bridged. My question though is about the perko. I should have the starter wire on the common and the batteries on 1 and 2, correct? The sound system battery was the only one tied to the perko. Just trying to clean everything up for this season and do surgery once it gets too cold.
    2008 Sunsport 22v
    Apr 2012
    Lake Wylie NC Area
    Everything but the auto-bilge, goes through the common output of the switch.
    Michael
    Mikes Liquid Audio
    Aug 2018
    Would this wire/breaker be for the auto bilge? I have the heavy gauge positive and negative coming through the floor to the right of this with another smaller ground that seems to be paired with this wire. Both are about the same size.
    2008 Sunsport 22v
    Apr 2012
    Lake Wylie NC Area
    The Auto-bilge would be a brown wire, about 18ga with an inline fuse. That looks like the helm BUS supply.
    Michael
    Mikes Liquid Audio
    Jun 2012
    Knoxville TN
    ^^ This was how my 07 was wired. That was the main helm breaker ^^
    2018 Supra SL400
    Aug 2018
    Ok. I didnít see any brown wire under there but our bilge has constant power from somewhere even though the float switch no longer works. In the process of replacing the pump. Iím just trying to get this temporarily cleaned up and the plan is to get some hdpe sheet in the offseason and build an actual amp rack and do everything under there correctly.
    2008 Sunsport 22v
