Results 1 to 6 of 6
    May 2020
    Exclamation 89-90 TS6M Rudder needed
    I need a rudder, mine was broken when hired hauler snapped mine .
    I tried the replacement from SKIDM but the collar for the rudder shaft and the rudder shaft are too long and press against the fuel tank.
    If I could find a OEM rudder the problem would be fixed.
    Anyone have One?
    Larry
    [email protected]
    I have one off a 86 comp . Give me the shaft measurements and I will check.
    May 2020
    Shaft is 5 1/2' and diameter is 1"
    Thanks
    larry
    443-994-2031
    May 2020
    Thanks
    larry
    443-994-2031
    The shaft on mine is 6'' long and 1 1/8'' diameter. I do have the the complete assembly including the port and arm.
    May 2020
    sounds like it will work
    can you contact me at 443nine nime four 2zero 3one?
    or email 330jetjoc at g mail
    Thanks
