Results 1 to 3 of 3
    Jan 2020
    Default Stiff steering ?
    My 92 Supra Comp steering is very stiff while underway. On the lift, or at idle in gear it is ok, but once underway, it is a two hand effort to make turns?
    I have had Centurion's, Malibu's, and Moomba's and could steer them with 1 finger, but not this Supra.
    This is my first season with this boat and I am sure everything is original?
    Would a "old steering cable" feel free ( not 1 finger free) under no load and stiff underway? It has a new 4 blade Acme on it, but there was no difference in the old OJ 3 blade.
    I have yet to disconnect it from the rudder because its out on the lift.
    Looking for any hints or common steering issues with these older boats?
    Jul 2007
    Flowery Branch Georgia
    Check the rudder port.
    Jan 2020
    I checked the rudder while it was on the lift today. There is slop side to side and front to back so I will try to repair it at my next chance.
    Do you happen to know if a 92 Supra would be a cord type packing or if it was the tap in seals and grease fitting? It would be nice to have it ready before I tear in to it, so as to cut some of the down time.
    Also, I was able to turn the rudder side to side easily from in the water so I think the cable is ok for now.
    Thanks again Michael.
