Results 1 to 3 of 3
    May 2018
    Default 2015 Supra 550 SE Anti Freeze
    Ive noticed the last couple trips on the water that my 2015 supra 550 SE anti freeze is low in the coolant reservior at the end of the day. Obviously there is a leak in the coolant system somewhere. When I turn my bilge pump on I can see a tint of the green anti freeze coming out of the bottom of the boat. When lifting the engine compartment you can smell a small hint of anti freeze, I fill it before we go each trip and there is a small amount left in the bottom of the reservior after a days useage. Any ideas where to look before having to tear the boat completly apart?
    THANKS!!
    Apr 2018
    If you have a heater, check hose connections on the heater.
    May 2018
    Sounds like a good place to start. THANKS!!
