Results 1 to 4 of 4
    Jun 2020
    Default 2018 SL450 Ballast/Bilge Question
    I have a 2018 SL450, recently when I am filling the ballast it seems like the bilge is kicking on after I fill the ballast. When I look in the engine compartment and where the center drain plug is there is no water but the bilge seems to be dumping a lot out. The 2018 has a sub-ballast system...is it possible that this is somehow leaking and it is triggering the bilge. This only happens after I fill the ballast, and just started happening recently. Thanks in advance for any help.
    Apr 2018
    My guess is one of your subfloor ballast bag fittings or hoses are leaking.
    I would imagine it’s a coveted warranty item and you should still be under factory warranty.
    Jun 2020
    Do you know if there is any way to visually inspect the sub ballast area?
    Apr 2018
    I would start by unbolting the center floor panel. I would guess that would get you a quick visual
