Results 1 to 3 of 3
    Aug 2020
    Default swell plate locked down
    New 2021 supra, 2nd time on the water left swell plate locked down. I cycled the key and turned everything off and on again and it is still down. Any suggestions?
    Quote Originally Posted by cjazmyn1 View Post
    That is usually the first thing the dealer tells you: Turn the batteries OFF, put the key in, let the system cycle, then start the boat.
    Does the plate change if you have AutoWake on? Wondering if you turn-on AutoWake and had the system try to adjust the plate settings vs manually trying to move the plate up/down.
    Long shot - might try to switch the batteries to 1&2. That might help if you have a voltage issue, but this sounds different.
