Not sure what this is, but would like to put it back where it belongs...
2011 Supra Launch 242
Lake Entiat, WA
Lake Washington
Bilge pump intake screen
Michael
Mikes Liquid Audio
Yep, I think my 07 Supra had something like this. When I replaced mine, I do not recall if it had a screen that sits in the blue bottom part that clips in/out.
https://www.bakesonline.com/bilge-pu...ra-750gph.html
If you unclip the pump from the bottom plastic housing, that screen sits under the main pump. You will see the hole where the water is pulled into the pump.
I was fixing something my boat today and unclipped my center pump from the bottom of the boat. There is where the screen was sitting. Wanted to check if it was clean.
If I were you, I would check that your bilge pump is connected properly and attached to the bottom of the boat/that bottom housing I'm referring to.
Thanks! Will do...
Lake Entiat, WA
Lake Washington
