Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. #11
    Jun 2020
    Outer 1x6 stringers in.
  2. #12
    Dec 2015
    Lake Nottely, Blairsville, GA
    Quote Originally Posted by Gaducker View Post
    This floor was completley rotten, has anyone got any pics of the holes in the deck where the wires and cables from the wheel go under the deck and into the center engine compartment?
    I can take more if needed and/ or measurements for you. You have 4 holes for bow vents - 2 port and 2 starboard. Battery box that sits in-between stringers on port side with small hole for battery cables. Center hole is for cooler drain plug. Obviously, throttle, engine harness and steering cables on right side at helm. Of course, ski pylon is just front of engine box.
    1985 Supra Rider
    1986 Supra Sunsport Skier
    1987 Supra Marauder
  3. #13
    Jun 2020
    Mine had a 90 and a hose for the cooler drain.
  4. #14
    Jun 2020
    Those vents just go back into the middle of the big stringers?
  5. #15
    Dec 2015
    Yes, at the very front of boat (start of bilge let's say), allows air into the engine compartment and then have 4 vent holes on transom to exhaust air, one exclusively for blower. Some boats will have two blowers.
    There is maybe 1.5 inches to wood underneath the four vent holes, then it begins to slope downwards just flattening out before ski pylon. The slope allows any water entering boat from bow to enter into bilge along with water from built-in cooler. The bilge pump sits at the lowest spot which is between the ski pylon bracket and front of engine.
    In the first pic below, I shined a flashlight into front left vent hole so you could see better. Hard plastic pipe you see in pics is to protect engine wiring harness.
    Hope this helps. Again, if you need any measurements or anything, be glad to help.
    1985 Supra Rider
    1987 Supra Marauder
  6. #16
    Jun 2020
    All the stringers and cross braces laid out.
  7. #17
    Jun 2020
    Glassing stringers.
