Results 1 to 10 of 11
    Jul 2020
    Default Walter V drive rebuild
    My boat is coming up on 2,000 hours and I’m rebuilding everything this winter. I’m starting with the V drive. I figured I would document it here in case anyone else gets into this project. The boat is a salt boat with closed cooling, but the bilge did a number on the v drive exterior. Photos attached. It’s getting washed tomorrow and then sand blasted. So far I did all of this with a needle scaler. I didn’t take pictures after I tore it apart but I will update later.
    I’m calling Walter tomorrow to order everything. All gaskets, seals, bearings, hoses, and a good bit of hardware.
    Wowza . . . what are you using to refinish the outside and try to keep the rust away?
    Will it still be a saltwater boat?
    Jul 2020
    No, she’s now a fresh water only boat!! I’m sandblasting all of the exterior parts and having them powder coated. I called Walter today and the rebuild kit is only 480 for all the bearings and gaskets. Sure beats 5 grand for a new one. After this I’m diving into the ZF trans and doing a full rebuild on the engine, every sensor, and electrical component on the engine is getting replaced, and quite possibly the wiring harness. Salt water is tough on these things. I bought the cheapest v drive Supra in the country this summer expecting a project. This sure is a project, I’m just glad I got to run three tanks through it over the summer. Next year is going to be awesome!
    Jul 2020
    At the powder coat guy now. I can’t wait to see it all back together.
    Sounds like you are doing it right. Good for you.
    After looking at saltwater boats, you are a brave man. That crap gets into and on everything.
    Jul 2020
    I wasn’t worried because it has fresh water cooling. I knew it needed manifolds when I bought it. This was unexpected.
    Jul 2020
    Powder coat guy sent me this today. Can’t wait to see it in person and then get it reassembled.
    Jul 2020
    I have it loosely assembled. Waiting on gasket and seal set. I didn’t want to forget how it went together so I partially reassembled it for now.
    Jul 2020
    Plenty more to go after this project. (My tower is off so the boat fits in the garage)
    Jul 2020
    Almost finished!
