Results 1 to 9 of 9
Thread: Battery switch
    Oct 2020
    Default Battery switch
    Any one ever re-position the battery switch over by the bulkhead along the right side of Capt seat? Seems like all manufacturers like to put it in an area by the ob seat in a small door. Why not do away with that and put it over by the driver??
    Jun 2012
    Knoxville TN
    Probably b/c most batteries are mounted in the obs hatch. Short distance for battery cable. Some models had them in the center of the floor.
    I do not mind the little door in the walkway. Better then lifting the seat.
    2018 Supra SL400
    Dec 2015
    Lake Nottely, Blairsville, GA
    Nautique has been doing this for years. I drove a 2015 and the switch was on the driver's side inches away from the keypad ignition.
    Made perfect sense compared to Supra's let's put it where nobody will ever find it and can't reach it if they do find it engineering.
    1983 Supra Beast
    1985 Supra Rider
    1986 Supra Sunsport Skier
    1987 Supra Marauder
    1991 Supra Comp ts6m
    2012 Supra Sunsport 242
    Jun 2012
    Knoxville TN
    It does. You stop cruising and are getting ready to anchor. You want to switch the #2 battery for the stereo while sitting in the cove.
    At least the walkway is better than under the seat . . . .
    2018 Supra SL400
    Jun 2020
    If it's hard to find, it means people who don't belong in my boat won't be able to purposefully turn on my batteries and ruin my day.
    My buddies boat bat's were dead one day after kids had been in the boat, doing stuff that kids do. The adults on shore just thought they were jumping off the bow while it was anchored in the cove. He found the ignition in acc, transmission engaged forward, and bilge pump switch on. Luckily no kids turned the key all the way. My last boat the battery switch was in the starboard rear locker. It was a PITA, and we frequently forgot to turn it off.
    The new Supra's need to have a T-plug holder that blocks access to the battery switch. That way, you don't forget either of them. The Nautique has the t-plug holder on the dash, which is smart.
    I will agree that the battery switch somewhere in the drivers console would make sense, but if it were, I couldn't turn it off after lowering the tower.
    2020 SA 450 in my future? We will see
    2017 Sanger V215sx. We call it Viagra because it's the little blue boat that gets everyone up (For Sale)
    Jun 2012
    Knoxville TN
    Quote Originally Posted by 2in2out View Post
    I'm forever crawling under there with the tower down for some reason or another. Sucks.
    Correct - not many easy access points with the tower down.
    2018 Supra SL400
    Dec 2015
    I should add, I never switch mine back and forth when I’m on the lake.
    When I show up for the weekend, once I contort my body underneath the OB seat, it gets turned from Off to 1+2 and that’s it until the weekend is over. If I’m listening to music for long period, it’s most likely on the lift at the dock with charger plugged into AC.
    So, it’s not terribly annoying for me but Supra could have done a better job to begin with.
    Having said that, if I spent over six figures for a surf boat, I’d expect it to be at the helm.
    1983 Supra Beast
    1985 Supra Rider
    1987 Supra Marauder
    Apr 2018
    Love the walkway door location.
    Didn’t care for the under seat location, but it makes sense to put it close to where the batteries are located.
    Jul 2010
    N.W. Suburbs Chicago, IL
    My battery switch is located right at the helm on my boat. Not sure when Supra went away from that but they had it right in '86 at least.
    '86 Comp TS6M - Reborn 2016
    Riding a HO Sports CX Ski
