Results 1 to 4 of 4
    Sep 2020
    Default Lenco marine actuator failure
    Has anyone had to replace the center tab actuator ? Do you know which model I should order.
    Lucky I checked under my boat today, saw that the actuator had failed. Explains why the center tab was not working from steering wheel!
    Sent from my Pixel 2 XL using Tapatalk
    Apr 2018
    Should be covered under warranty and they are not a high failure part.
    I think they are fairly cheap to replace.
    $150-$200 new
    Sep 2020
    Quote Originally Posted by Larry Arizona View Post
    $150-$200 new
    Yes, covered on warranty. Now I have to wait for the warranty Gods to ok the fix as apparently they are backed up.
    Strange that this has 22hrs on it and it failed.
    Apr 2018
    Quote Originally Posted by svienb View Post
    Lol, moving parts my friend......moving parts.
    If it moves, it can fail.
    Most likely an assembly defect.
