Results 1 to 5 of 5
    Default Skiing behind a 2006 Launch 20
    I'm about ready to give up on this boats wake. When you've had the best water behind a mid 90's ProStar you might get spoiled. I normally run at 32 mph and 15 off. I haven't found a good setup to on this boat for the least amount of wake. If anyone has a good setup and if I need to run faster please let me know. Is there an optimum wake plate setting, speed, and front ballast to achieve decent water?
    N.W. Suburbs Chicago, IL
    Got any pictures of the wake that you are getting now along with the settings/configuration of the boat for that wake?
    Its called a Launch because it was made to create a big wake to launch a wakeboard. Survival skiing is about the best you will get with that boat. My best advice is to learn to wakeboard or buy a comp.
    ^^ This ^^
    Dec 2013
    Yep, lost cause unless you can get the boat up on foils...
