Results 1 to 2 of 2
Thread: wake plate
    Oct 2020
    Default wake plate
    I have a 1991 Supra Mariah at the transom there is a mechanical wake plate made of aluminum that is adjustable.
    I really do not know how it should be set.
    I mostly slalom ski and do not know to leave it level with the bottom of the boat or lower or raise it.
    Does anyone have any knowledge about this plate?
    The tab works a bit like a fixed trim tab. By pushing it down you will create some lift at the back of the boat, however this can make the front of the boat stay down and plow water and cut waves more than it rises over them.
    The opposite happens if you pull it up, the bow will rise and it will go over waves better but the back of the boat will ride deeper in the water.
    If it is level now and you like the wake it is probably fine where it is. If you want the wake to be smaller and firmer you could try pushing it down in small increments until you feel the bow plowing water at speed.
    I think the surfing crowd likes to run them up and have the back end of the boat low to shape the wave more.
    Hope that helps.
    Sent from my moto e5 supra using Tapatalk
    1986 Supra Sunsport Skier with 351W and swivel spotters seat
