Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
  1. #11
    Jun 2010
    Ontario, Canada
    I like that Bimini, looks awesome Michael!
  2. #12
    Oyama, B C , Canada
    Bracket(s) are part of the overall mirror . Not separate piece(s)
    U shaped with tightening screw that allows one to place U shaped bracket(s) over windshield frame and
    Then simply tighten down with built in thumb screw.
    Easy peasy!
  3. #13
    Dec 2015
    Lake Nottely, Blairsville, GA
    The PTM Edge mirror is much better than the CIPA mirror. It may be more expensive but has a much better clamping bracket which folds down and cover can go right on. I switched my CIPA out on my 242 when the bracket busted. You had to constantly tighten it down and then the bolt stripped. I haven't had to adjust my Edge bracket a once since install couple years back. It has 20" mirror that allows you to see all behind you.
    ptmedge.com
    1983 Supra Rider
