Results 1 to 6 of 6
Thread: VSR Grounding
    May 2021
    Default VSR Grounding
    Hello,
    Where should I attach the ground wire from my VSR? I have a 2011 22v Sunsport. I have read a couple of posts that have said to attach it to the negative terminal of my starter battery. Do people agree with that?
    Thanks!
    Apr 2012
    Lake Wylie NC Area
    All grounds are common.
    Michael
    Mikes Liquid Audio
    May 2021
    Mike,
    I apologize for being a newb but what does that mean? Where should I attach the wire?
    Thanks,
    Kit
    Dec 2013
    What's a VSR?
    What Mike is trying to say is the correct answer normally is the easiest ground to reach from where the component is located. At the rear, anything on the engine block, left front the battery, and under the dash any common ground wire.
    If the VSR? is high current, then it will take some care to provide a substantial enough cable to ground to.
    May 2019
    Arizona
    Quote Originally Posted by CJD View Post
    What's a VSR?
    Voltage sensitive relay. I had to look it up.
    Looks like the ground goes to a common bus bar and not necessarily the battery.
    I just found this schematic
    https://productimageserver.com/liter...al/58652OM.pdf
    Apr 2012
    Lake Wylie NC Area
    Quote Originally Posted by kithagen View Post
    Mike,
    Thanks,
    Kit
    Electrically, all grounds are connected to each other.
    Michael
    Mikes Liquid Audio
