Results 1 to 6 of 6
    Jan 2004
    Austin, TX
    Default What material is used for rudder port reinforcement?
    I've damaged the rudder port, and I can't find any fiberglass shops that can do the work in a timely fashion, so I might have to do it myself. What is this laminated material that looks like plywood? It delaminated from the stress, so it needs to be replaced (or possibly repaired, but I doubt I can get it out with destroying it). Thanks.
    N.W. Suburbs Chicago, IL
    Most likely plywood, if you are pre-composite stringers which is '91 then definitely plywood.
    Jan 2004
    Austin, TX
    It's a 2001. I thought they advertised that there was no wood in it, but that may just be the stringers. Either way, I assume there are better materials than plywood to use in the repair, so the real question is what *should* I use?
    Looks like Marine grade plywood to me . If you use plywood go to www.rotdoctor.com and get their CPES coat the wood 3-4 coats after you drill the holes then glass it in. I have heard some use Coosa composite board but I have no direct knowledge of it.
    Jan 2004
    Austin, TX
    The material is some sort of filler. Anybody know what it is?
    Jan 2004
    Austin, TX
    It appears to be talc bog - polyester resin + talc. Could be other fillers instead or in addition to talc.
