Results 1 to 2 of 2
    Aug 2018
    Question 2021 Supra SA Surf Settings and Lead Amount/Placement
    Hello,
    We just got our SA and trying to dial in the surf wave for the family. I am curious on other owners surf settings for a 2020 or 2021 SA (new model)? Do you add lead? If so, how much and where are you placing it? What surf settings are you using (pitch and roll amount)? Do you use autowake or manual? Thank you in advance.
    Brian
    2021 Supra SA 450
    Depending on your crew size, people are running 500-1000#s of lead. Mostly under the small seats in the back, more on the port side. Some weight midship. 75/25 splits for those areas.
    Regular Wave:
    Pitch around 8.6 to 9.0
    2.5 to 3 degrees roll @ 11.2 mph.
    85% swell and 25% wake.
    Each boat may not be calibrated the same.
    Adjust weight underway to dial it in. Powerful wave with a lot of push.
