Results 1 to 10 of 17
    Default motor not starting after warm
    Motor not starting after warm, could this be vapor lock. It will start and run fine after it cool's off. Is there a way to stop vapor lock from happening.
    Thank you
    Mike
    N.W. Suburbs Chicago, IL
    More information would probably be helpful here such information like year, engine and fuel delivery method.
    Apr 2007
    Cincinnati
    Same problem. I had to add a second hi pressure fuel pump because original pump is too close to the engine and the heat vaporizes the fuel.
    Aug 2019
    St. Louis , MO
    Quote Originally Posted by bonedoc View Post
    Just curious, what year and engine do you have? Carb or fuel injection? I guess I've been lucky as my 04' hsa not had this problem. The pump is mounted on the lower back corner of the engine block.
    Apr 2007
    Cincinnati
    2007 Supra Launch 22SSV 340hp Indimar
    Apr 2007
    Cincinnati
    2007 Supra 22SSV 340hp Indmar
    Had vapor lock a few times during the early days of my 2007.
    Started running the blower during water activities and using 100% fuel (no eth). Solved the issue.
    Jul 2019
    Anacortes,Wa
    check your ignition coil. my 05 launch would fire up and run fine. after we ran for a while and shut down to swim and hang out, if I tried to fire back up it wouldn't fire up until I opened the engine compartment for it to cool down. I chased all this stuff these guys are saying (adding secondary fuel pump, vapor lock...blah blah) I would bet its ignition related. Hope that helps and good luck. also add marine 360 with every fill up.
    Sep 2020
    Nebraska
    I am having the same issue on my 06 Sunsport 24v with the Assault 325. What motor do you have and did you replace the ignition coil yourself? If so, where did you get the coil from?
    Sep 2020
    Nebraska
    After getting it to start would it run rough? I was out on the water for a few hours and it was running great, parked it for an hour or so and then it wouldn't start. Got towed back, pulled it out and then it popped right off, so I put it back in the water and tried to rev it up, but it was sputtering really bad with little to no RPM change with throttle input.
    2006 Supra Sunsport 24v w/325 Indmar Assault EFI
