check your ignition coil. my 05 launch would fire up and run fine. after we ran for a while and shut down to swim and hang out, if I tried to fire back up it wouldn't fire up until I opened the engine compartment for it to cool down. I chased all this stuff these guys are saying (adding secondary fuel pump, vapor lock...blah blah) I would bet its ignition related. Hope that helps and good luck. also add marine 360 with every fill up.
