Results 1 to 4 of 4
    Jul 2021
    Default 2018 SA450 Seats
    Does anyone know if the cushion/seat for the flip up table/wakeview seat can be replaced with one from a newer model with the sea deck flooring so it wonít tear from walking on it?
    Apr 2018
    Quote Originally Posted by Robert L View Post
    You can probably get an upholstery shop to modify your seat for you with a sea deck insert.
    I am sure you could buy a replacement seat from SC through your dealer for a 2019, but I think the vinyl and patterns changed on the SA from 18 and 19, so it may look weird.
    It would also be ridiculously expensive.
    Jul 2021
    Thanks for the response. Most likely more economical to get it done locally.
    @KnoxMojo had a local Knoxville upholstery shop put a step on that seat for a 2018 SA. Looks good.
    I emailed SC about it last year for my 2018 SL. The new seats (2019) are built different to support the plastic backing the gator step mounts - per the email. I was looking to buy that plastic backing piece, have it mounted by an upholstery shop, then slap a pierce of Gator Step. No luck this route.
