Results 1 to 10 of 16
    Sep 2019
    Default 1994 Supra Sunsport Bent Rudder - repair options or source for used replacement
    Rough day at the lake. High winds pushed me into shallow water and my rudder bent sideways. I get my props repaired at Jim's Prop Shop in Denver and I will call there on Monday to see if he can repair bent rudders as well but looking for repair shop suggestions as well as a source for a used rudder if anyone would have one. I'll attach pictures so that if anyone has experience with this maybe they can tell me if it's bent too far to be repairable. Also, curious as to what a repair like this should cost. Thanks in advance for any advice or recommendations.
    The prop shop should be able to straighten it.
    Dec 2015
    Lake Nottely, Blairsville, GA
    I probably have several of these but any metal shop could bend that back into shape.
    1985 Supra Rider
    1986 Supra Sunsport Skier
    1987 Supra Marauder
    Sep 2019
    Thanks for the replies. I know that last season Jim’s lead time on prop repairs was pretty lengthy but I’ll know more on Monday. I’d still like to use the boat this season. If he can’t get to the rudder repair soon and I can’t find a local metal shop to do it then I’ll check back with Mischief IV on seeing if I can buy one from you. Probably not a bad thing for me to have a spare rudder anyway.
    Dec 2013
    Yep, brass is infinitely repairable. They should check the post carefully for cracks, but other than that it is a straight forward job. Also, if he is backed up for too long, I would not have a problem running it that way for the remainder of the season.
    Sep 2019
    That's good to know (about just using it as-is for remainder of season). I wasn't sure if I would cause other problems or not by using it with it that bent. Hopefully it goes back together easier than it came apart. I hope I didn't mushroom the top of the shaft too much by how hard I had to hit it. I think it was hanging up either on the square key or the pinch pin while I was trying to get it out of the steering collar.
