Been awhile since ive bench tested a starter, but it sure does look like it spins up slow. Could just be a total coincidence that the starter craps out at the same time you are testing the new dual bank setup.
With that said, yeah, if you want the LED output direct to the battery, no telling what it would cause the ACR to do, so blowing that 80A fuse is possible.
Honestly, I never use the LED or the SI terminals on single engine trailer boats. All you need is the ground control.
Michael
Mikes Liquid Audio
