Results 1 to 5 of 5
    May 2020
    Default Dash gauge’s not turning on 2008 launch
    When I turn the key to the on position I have zero gauges turning on. The boat will start the fuel pump and turn over fine. The boat will also run fine but no gauges. This started happening intermittently but is now full time. I have looked for a fuse with no luck. Does anyone have any recommendations on where I should start? ( I have replaced the ignition key module already)
    Dec 2015
    Lake Nottely, Blairsville, GA
    Quote Originally Posted by Evan46 View Post
    Is there a circuit breaker before the fuse block? My 2012 has a breaker to cut all electronics next to battery cut off switch.
    1985 Supra Rider
    1986 Supra Sunsport Skier
    1987 Supra Marauder
    May 2020
    I have a complete new mmdc, gauges, and wire harness. I am trying to replace but 4 of the five gauges have the same wire colors and pin set up. How do I find out which cluster goes to which gauge?
    Dealer might be able to help you out on their computer with online diagrams.
    May 2019
    Arizona
    Check power at the ignition switch on the accessory side as well
