2002 Launch SSV ballast issues
What do I need to do to the Hippo system to improve fill times. I know there is only one fill pump before the selenoid valves. I was wondering if anyone had added a pump for each sack. Just any suggestions would be great. The system fills way to slow.
try going about 35 mph for a few minutes, then when you stop leave the pumps going. What I do is just fill them on the way to the cove, just have someone in the back check for when the rear ones fill, they usually only take about five minutes when moving
