Once the hull was stripped down of all wood, then the process of glassing in the composite started at the transom, first for the lifting ring, then for the blower mount and speedo tubes, followed by the bow ring. Then composite was added for the swim platform mounts once the stringers were set.
First pic here show some of the old wood that was, wait for it...the original outer two stringers.
So then you have to ask yourself, wait a minute, I thought I had a total stringer job done back in 2009? All new wood.
According to the invoice it was but according to the rotten wood laying there, it was total con job.
fraud
frôd
noun
- A deception practiced in order to induce another to give up possession of property or surrender a right.
- A piece of trickery; a trick.
- One that defrauds; a cheat.
I will tell you how I found this out as we get more into this thread but for now, let's focus on the good work going into the hull.
The long piece of wood in forefront is the original outer stringer. 38 years old.
Transom
Ski Pylon gets sanded before a new coat of Rustoleum is applied.
