Results 1 to 4 of 4
    May 2022
    Default Water Depth Finder issue
    on my 2008 22ssv, the depth stays on 3.3 ft (on or off the trailer) and the water temp 32, never moves. Bad triducer? The speedo works just fine.
    May 2019
    Arizona
    Check for corrosion on the wire connectors
    May 2022
    Quote Originally Posted by Turbinesurgeon View Post
    I assume on the triducer itself?
    May 2019
    Arizona
    Quote Originally Posted by rlm007 View Post
    Yeah, check the connections down in the bilge. Had issues with mine and found corrosion inside the connector. Use some contact cleaner or deoxit and see if that helps
