Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Thread: 1991 conbrio
    May 2003
    Kansas
    Default 1991 conbrio
    I have a "91 Conbrio, runs to 2200 rpm, then backfires, no power, runs great below 2200???? will go to 3500 or so when initally put into water, but only for a minute??
    Aug 2002
    Tn.
    Default Slo' boat
    Please specify motor make and model. Did this problem start immediately or slowly evolve. How did the boat perform at the end of last season? Please list any recent service work, winterization methods, and servicing dealer, we should be able to get you up and going with the above info. Brian Raymond
    May 2003
    Kansas
    i just purchased it in march, has less than 200 hrs, a 351,pcm, serviced regularly, had a new carb put on last fall,
    May 2003
    Kansas
    the previous owner states that the Knock sencer should be unhooked, I did this, but not positive where it is, unhooked the one on the rear left head
    Aug 2002
    Tn.
    Default Stuff 2 check
    Does your boat have a prestolite distributor with points and condensor, or an electronic module?Brian Raymond
    May 2003
    Kansas
    it is electronic, with a bank of coils on the back of the motor
    Aug 2002
    Tn.
    Default Boat
    I am getting conflicting statements, if it is carbureted it will not have a knock sensor or multiple coils. If the motor is a PCM ProBoss, we are getting closer.Brian Raymond
    May 2003
    Kansas
    the cover says power plus, po=rotec electronic engine management system by pcm
    May 2003
    Kansas
    it is a holley carb, and diffenently electronic ignition..
    May 2003
    Kansas
    here are the no.s....
    model...PLD-PR-R12PT, serial no. 303677
