I need a small part
I need to know where I can locate a bolt for the stabilizer plate adjustment arms on an 89 comp. It looks to be 3/8" SS with an oversized flat head. Not a standard hardware store piece. I talked to one dealer and they said I would have to order the whole assembly. $$$$. Any help would be greataly appreciated. I hope to have it in the water in a week.
89 COMP
screw it
Contact SkiersChoice(865)856-3035x130. The TechServ. dept. will be able to help you out.Brian Raymond
Brian,
You are the man. I got it now. I just have to get my boat to make sure it fits. I was planning on using some lock-tite to be sure it stays. Do you see any issue with that? To everyone else lurking, Skiers Choice customer service is unmatched from any industry. I would highly recommend them.
89 COMP
Nothing beats a good screw
Happy to help, no locktite is needed. Look at the end of the screw, there is a yellow locktite added on by our stainless vendor, that when tightened into the stansion, becomes almost nonremovable. Happy boating. Brian Raymond
