Just bought this boat and it needs a little work... any help with the following would be greatly appreciated.
Are there factory manuals available that cover the engine and electrical system on my 87 TS6M?
Specifically need dash wiring and through hull shaft packing and adjustments etc...
Bilge pump needs to be running constantly and I am not sure if it is coming by the shaft.... Also, how to access where the wake plate connects to the transom... one of the through hull connections is loose and leaking a lot of water into the bilge.
One speedo leaks a lot of water and a couple gauges are flakey...
Finally, it has a 3 blade brass prop... is that the original config? It has some damage, all three blades are curled forward... What are my options and for best performance pulling skiers and waker's?
