Results 1 to 7 of 7
    May 2003
    Commerce, MI
    Default Rubbing Compound?
    I have water lines on my 98 comp from it sitting in the water, will rubbing compound ruin the paint? Or does anyone have any other suggestions on removing the lines? Thanks
    1998 Supra Comp
    Default Rubbing compound
    I don't think there is any paint, just gelcoat and decal, and they are unaffected by rubbing compound. I use starbright boat wash or any (sodium triphosphate?) caustic wash, it's easier. They will tear up metal and flesh if you don't rinse well.
    Jul 2002
    Fort Wayne, IN
    I had water lines and tried about everything. Finally, I tried Sno-Bowl. It took everything off and did not harm the finish.
    95 Mariah 5.8 PCM HO EFI
    Jul 2003
    Illinois
    Muratic acid will remove the hard water. Or you can by a bottle of Spa Cleaner form a hot tub store it is a mild version of the Muratic acid. It works great.
    Kurt
    Guest
    Default Replying to Topic 'Rubbing Compound?'
    My 86 SupraComp had never been cleaned when I bought it last year. I just replaced all the flooring and carpet over the winter and decided to try and bring back the original black shine. The only thing I found that works is a product by 3M called Finesse-It. It's very heavy grit and takes a lot of time and elbow grease, but it looks brand new!! Expect to pay approx. $35 per bottle (I only used 2/3 of my bottle for the entire boat). After rubbing compound, you may want to use some yellow wax just to keep it shiny all summer. Good luck.
    Jun 2002
    Michigan
    be careful w/ the rubbing compound on the colored gelcoat, you can rub it right out! Any good toilet bowl cleaner will work. Personally, I use Muratic acid and cut it w/ water by about 40-50%. Make sure you thoroughly rinse your trailer down and driveway(if it's blacktop) as it will tear that up too!! I do mine at in-laws w/ gravel driveway!
    SuckMyWake
    Nov 2004
    Red Lodge Mt.
    On my 01 SSV I use 3M light grade rubbing compound and then wax. My boat is black and off white, I've never had it mix the two colors or distort any colors. Although I do all of the rubbing by hand and not with a buffer. It is hard work but you will never find a singal water spot on my boat, when people see it they think it is new. The rubbing compound will also minimize small or shallow scratches. The interior I use products that are rated with a UV protectant. In the end its worth the work.
