boat leaking
My 89 Comp seems to be bringing on water, but I can't figure out from where. All plugs are in and wrapped with teflon tape so they aren't leaking, the shaft just got new packing rope so it hasn't started to leak yet. All plugs in the motor's water jacket aren't leaking, so I'm stumped. The only unusual thing i've noticed about the water that seems to be leaking in is that there are chunks of foam floating in it. The foam is tan/light brown and looks like the type of foam you would spray in a crack and it would expand. I can find similar foam around the exhaust tubes that dive into the hull of the boat on their way back to the transom, but no foam seems to be missing.
Since the boat just got refurbished from the factory this last winter, I'm thinking that water is leaking in from somewhere that didn't quite get sealed up right. Has anyone had a similar problem?
-Mark Callahan
1989 Supra Comp TS6M
Dodge Ram 3500 for haulin'
