Results 1 to 4 of 4
    May 2003
    Colorado
    Default mounting hardware for engine cover
    I need to remount the hinges that hold my engine box, but I'm torn between screws or bolts. If I use screws then I won't have an ugly bolt head on the outside of the box, but screws will strip out eventually. I think the box was originally mounted with screws but I can't remember.
    Anyone have an older supra around my year or would recommend screws over bolts?
    -Mark Callahan
    1989 Supra Comp TS6M
    Dodge Ram 3500 for haulin'
    Jun 2003
    Great Lakes, IL
    Default Screws or bolts....
    I have screws in mine right now, they are stripped, but I believe that they have been in there for awhile. I am going to replace them with ones that are a little bit bigger and will be more secure, the ones it has now are long, but quite small.
    I haven't taken my cover off too many times so I shouldn't have too much of a problem with them.
    The screws are easier to undue. But if you aren't going to be taking the cover off, I would use the screws, otherwise use bolts and a few extra minutes getting it off for maintenance and such won't be that big of a deal to save yourself from having to replace stripped out screws.
    88' Supra Bravura
    May 2002
    Charlotte, NC
    You could use larger screws (be sure to use stainless steel) or you could go buy a 3/8" dowel and drill out a 3/8" hole. Glue the dowel in the hole, cut it flush and then pre-drill a new hole for your old screw. It'll be good as new.
    2005 Supra 21V
    1990 Supra Sunsport Classic SOLD
    Sep 2003
    Everett WA
    Default Screws or bolts?
    This year I glued machine screw inserts in to engine cover since the screws would not tighten any more. Then used stainless steel machine screws so not to have any corrosion.
    Electro
    Electro
