Transmission problem
Dear friends
I'm crossing probably a major problem with the transmission (Velvet Drive) of my Comp 90 (PCM 351). The transmission overheated and smoke came out while I was skiing. Next day I change trans oil, start engine and shaft was rotating while throttle was in neutral position, I add some acceleration (without having forward or reverse) and the shaft was rotating same as reversing. After a while the transmission overheated again.
Do you have any suggestions what this problem could be or what I have to repair?
Dimitris
