Hi. I managed to hit a rock while pulling my son kneeboarding (about 15 mph) behind our 2001 Launch SS. It bent 2 blades on the prop and scraped the other 2. It also sheared off the rudder. I've pulled the prop for repair/replace and removed the rudder assembly for replace. Thanks to this forum, I know how to get the parts. My question is how can I tell whether I bent the prop shaft or the support bearing? I placed a straight edge along the shaft between the bearing and where the shaft enters the hull, and could not detect any wobble or gaps when manually turning the prop. However, I'd like to know if there's a way to measure or detect if I bent the shaft or the bearing/support. I appreciate any suggestions.
thanks
steve
(sorry for the double post, it came up blank the first time)
