Page 1 of 2 12 LastLast
Results 1 to 10 of 19
    Sep 2008
    Default transom stereo remote
    Anyone have pics of where the stock transom remotes are located? I was thinking of adding one and wanted to know where the best spot to locate one would be.
    Feb 2009
    Minneapolis, MN
    I would love to do this but I can't find any kind of transom remote for a reasonable price. Which to me would be like $30-50.
    Sep 2007
    Mine is just above the "A" in Supra.
    07 Launch 24SSV Gravity Games
    My Install Gallery
    Oct 2008
    Northern Colorado
    Same place on my 08 24SSV - just to the right of the "hand bar"
    When I installed mine, I put it on the exact opposite of center location as Jonyb. This made the task of routing the cable that much easier. I put the y connector at the stereo and ran the new ext cable behind the interior wall, behind the carpet in the ballast compartment right to the remote.
    -2008 Launch 21 V
    Apr 2008
    Europe, the Netherlands
    I installed the second remote not outside the boat but in the boat.
    This works better for me and it won't get cracked by wakeboarders or skieers.
    Also found an sollution to install my GPS without drilling.
    Oct 2008
    Northern Colorado
    MVD, I also use a RAM mount for my GPS, but I like your "pole mount" better than
    mine -the one I have uses a "U" bolt - but it works great, and I have it in exactly
    the same spot!
    Apr 2008
    Quote Originally Posted by tg0824SSVGG View Post
    the same spot!
    I filled the gap between the polemount and the pole with 2 pieces of rubber hose.
    I have the U-bolt for my motorbike but i thought it was to heavy for the boat
    Mount is:
    RAP-B-231U from rammount
    Feb 2009
    Tri-Cities, WA
    I put my remote above the run rail... Still haven't taken it out with it on. Thats where the old one was so I just had to drill out the hole a little more. I think it looks pretty good.
    2005 Supra Launch 22 SSV
    Semper Fidelis
    Feb 2009
    Tri-Cities, WA
    Quote Originally Posted by 87SunSportMikeyD View Post
    Mikey, I have my old remote that should work, I never used it though. It was hooked up to the kenwood that was in my boat when I bought it. I dont know if your deck has a plug for a remote. This remote has four wires marked, power, ground, signal, and light. No display, just buttons. Let me know if you want me to send you some pictures and we can work something out.
    Semper Fidelis
