Stuck ski Pylon
I am trying to remove the ski pylon from a 87 Saltare. The pylon is stuck in the tube bracket under the floor. I have taken all mounting bolts out and set screws and it will not budge. I need access to repair the lag bolt holes for the mounting bracket. Anyone have any suggestions other than cutting the floor out. Looks like a dangerous place to try to put some heat on! Thanks
