Results 1 to 4 of 4
Thread: Stuck ski Pylon
    Sep 2003
    AT WORK
    Default Stuck ski Pylon
    I am trying to remove the ski pylon from a 87 Saltare. The pylon is stuck in the tube bracket under the floor. I have taken all mounting bolts out and set screws and it will not budge. I need access to repair the lag bolt holes for the mounting bracket. Anyone have any suggestions other than cutting the floor out. Looks like a dangerous place to try to put some heat on! Thanks
    Sep 2003
    AT WORK
    Default Pole is out!
    Ok here is what I did. I cut a hole in the floor the width of the pole from the pole to the motor bilge area. I removed the front pulleys and impeller water pump and bracket and removed the pole bracket and all. I cut a larger hole in the bottom of the pole bracket so I could get to it with a press. The pole is a solid piece of aluminum. After 3 days in a 10 ton press with all the pressure I could put on it and spraying WD40 down in the tube it finally broke loose, gradually presssing out. You talk about stuck! I really do not see any other way this could have been done. I will have a small section of floor to patch and brace but nobody ever said life was suppose to be easy! Thanks to all who looked at this post. SHF49
    Jul 2003
    near Richmond VA
    Nice work. Few would have accomplished this.
    Are you going to re-mount it?
    Have you run into soft stringers under the floor?
    Sep 2003
    AT WORK
    Yes I will remount it. Some of the lag bolts were loose. I don't seem to have any stringer problem as the motor mounts and floor are solid. I intend to treat the wood in the stringers in this area with CPES from the Rotdoctor and fill the holes for the ski pylon mount with epoxy putty I got from them also. My biggest challenge may be getting it to dry out but I have all winter to get this done. I am mainly trying to get to a down the road problem before it is a major one. This is my first Supra but I have learned a lot from this forum. My thoughts are if my floor is good and the motor is mounted solid I should be in pretty good shape. Any input is appreciated. Thanks for your reply!
