Time to winterize again
I fog the engine through the carb until it stalls, and I disconnect the water pick-up and put in antifreeze. This year I couldn't remember how I did it last year so I just tried to suck the antifreeze solution up with the starter motor. What sequence do the rest of you use?
i check all the seals, both inside and out, make the sure the zipper is in good order, then grab my drysuit and hit it!
i only have to worry about overnight dips and the occassional real cold front that might last 3 days. i do consider myself lucky though.
when i do drain it, i have petcocks on the block and i disconnect the lowest water hose on the front of the engine....intake to raw water pump. gotta drain the shower too.
at least you guys can hit the slopes in the winter.
