So last fall I had some electrical issues where the battery would drain if hooked up, and wires would get hot and melt.
I ended up replacing the battery cables, starter solenoid, and got a breakerless ignition kit. ( http://www.skidim.com/prodinfo.asp?number=RP173072 )
That seemed to fixed the issue for months, until today. Now if I turn the key on (not starting the motor) The coil on the engine gets extremely hot and the volt meter on the dash starts to dip after a while. I've had my boat out once since I did the previous fix and it has been fine, and I've spent countless hours with the stereo on in the boat with no issues.
Is there a common part to check, and how should I go about checking this?
