Results 1 to 7 of 7
    Jun 2009
    ontario Canada
    Default engine in 1989 supra sunsuport ?
    does anyone know what engine is in the 1989 supra sunsport
    Im looking for new spark plug wires and am having a hard time finding out what engine is in my boat
    Sep 2008
    Parkersburg, WV
    The motor should have a PCM or Indmar nameplate screwed onto the intake manifold somewhere - I think 1989 is going to be a PCM. The nameplate will have a serial number that we can decode for you. Probably you have either a Ford 351 Windsor or a GM 454 - I don't think that Supra put a GM 350 in the Sunsport until later. Another easy check, if the distributor is in the front, it's gotta be a Ford and will be the 351.
    Clint
    www.waketheworldwv.com
    Jun 2009
    ontario Canada
    well the code is
    E8TE-8425-CB
    Apr 2009
    Rogers AR
    That's a Ford casting # so I'm almost positive you have the 351
    Go Balls Deep Or Go Home ! ! !
    Apr 2009
    Milpitas, CA
    Mine is a PCM 351 with a Holley 4160 carb.
    1989 Supra SunSport | ACME 480 Prop. | 13th Floor Tower
    Jul 2008
    Waterford, MI
    Go to my profile page, i have an 86 sunsport with a 351W. I have pictures of the engine on my page. If yours looks similar to that then it's a 351W!
    Jul 2007
    Flowery Branch Georgia
    Skidim has original equipment PCM wires in stock. Might as well change the points cap and rotor as well.
