What are some ideas for setting up my 2009 24 Sunsport for wakeboarding? Wake, ballast, length of rope?? Thanks
Dude lets see some pics of her
Go Balls Deep Or Go Home ! ! !
i have a 09 22ssv worlds. i wakeboard at 60ft .ballest as full as they will get.the wake is at lest 3feet tall. that is how i have mine done. my wife rides that way to.
Ifly and gornichec, welcome to the board and nice rides, espec yours ifly, i have the 09 21v worlds, lets see some pics guys
pardon me for hijacking
2009 21v Worlds 340 Cat
Doug
Throw some 750's in the rear locker and you will more than good. That boat with the stock Gravity III throws a great wake, its wide, and heavy. You will add another 700lbs with the 750 rears. For me, wakeplate about 50% makes for a great wake.
Does your sunsport have the walk-thru or play pen front seating? and lets see some pics!
White/Charcoal, 2011 VLX
2008 Supra 22SSV
Yes it has a play pin. I don't know how to upload pic or i would have 50 up
check out the FAQ section top left
Doug
If you have the play pen with the sunsport package you probably have the 400/600 lb bag in front. If you have the 400/600 lb bag you could probably upgrade the front to the 1100 lb bag. With the 1100 lb front bag, and 750 in the rears you would have an insane wake. You could also just upgrade the front to the 1100 lb sac and leave the 400's in the rear and it would also bump up the wake quite a bit. The 750's are nice in the rear for surfing, especially with the larger 24' boat, which you can also get a great surf wake out of.
FYI, The 24 SSV tows the gravity games pro circuit with the stock 1900 lb ballast system, you would be at 2900 lbs with the larger sacs for a crazy wake. Your hull design is identical to the 24 SSV.
To upload pics, when you are posting the message scroll down to "manage attachments", it will allow you to upload pictures. To reduce the size of pictures, I use a program called Irfanview, you can download it for free on the internet.
Last edited by docdrs; 02-21-2010 at 08:30 PM. Reason: you'll hurt yourself on those pins
2008 Supra 22SSV
That might sink my boat. it might be to soon for that trying to figure out where i can put a fifteen inch sub. Under the passers side.
