Page 1 of 2 12 LastLast
Results 1 to 10 of 16
    Aug 2009
    Austin
    Default Water spots on hull
    Does anybody know of a good and safe cleaner to use on the hull to clean hard water spots?
    Jul 2007
    Flowery Branch Georgia
    I use 30% white vinegar 70% water in a sprayer as part of my ramp side clean up. Its cheap and works great.
    Mar 2009
    Roseville, CA
    Meguairs makes a real nice water spot remover, its sprays on and is safe to use and wont harm the gel coat or scratch it. I have had good results with it.
    White/Charcoal, 2011 VLX
    2008 Supra 22SSV
    Oct 2008
    Northern Colorado
    I hvae used vinegar/windex/water - decent results.
    I have used Ducky - great results (http://www.duckyproducts.com/)
    I currently use Babes spot solver - great results.
    Remember - the longer you leave the spots, the harder they are to get off.
    I am putting a link to babesboats.com, but I buy from Bakesonline.com - the prices
    are about the same, but shipping is less. I bought a "bucket" directly from babes to get
    all the little spray bottles - but then I buy gallon refills from bakesonline.
    http://babesboats.com/prodSpotSolver.php
    http://www.bakesonline.com
    Todd
    Jul 2007
    TG08
    You are right the longer you let them go the worse it is. Our ramp side prosiger takes 45 minutes to an hour. The wife wipes down the interior with Malco and I wipe down the outside including trailer with vinegar. The boat always goes home ready to go out. I find if you wait untill you get home it doesnt get done. Once a month it gets a full detail.
    Aug 2008
    Austin, Texas
    The problem with Ducky is it takes off all the wax. Does Vinegar/water and Babes do the same?
    Skylar18
    2007 Sunsport 22V
    Oct 2008
    Northern Colorado
    If you mix Windex in - I think it does (water/vinegar).
    Babes spot solver MIGHT _ I only need to use it after being in the water
    for an extended period, like when I go to Lake Powell for a week.
    I use Babe's boat bright each and every time I pull the boat, and at least 2 times
    a year, I put on a coat of "Nautical Ease" - it's not wax, it's silicone based - and
    it DOES NOT come off with any of these products.
    This stuff goes on SUPER EASY - and sure makes for a slick, shiny - beautiful surface,
    I only wish I had found it years ago.
    http://www.nauticalease.com/products/ultimate.htm
    Todd
    Aug 2008
    Austin, Texas
    Todd,
    Do you use wax at all or that product in lieu of wax? I use Starbrite Polish with PTEF which does a pretty good job of keeping Water Spots from forming. We have pretty Hard water here in Austin.
    Skylar18
    2007 Sunsport 22V
    Apr 2009
    The Woodlands, Texas
    ditto on the vinegar and water. I have been using this mix on my boat for about 20 yrs now. I use 50 / 50 vinegar and water. I used to put a shot of windex but i found it would take off some to the wax. I currently have a black and yellow 22ssv and needless to say the black get the water spots so bad its rough on the towel during the wipe down. This vinegar and water works great.
    Oct 2008
    Northern Colorado
    Skylar - no wax - only the Nautical Ease (and Babes Boat Brite every time out) and the Babes Spot Solver rarely.
    (every now and then Ducky - which I have leftover - when I am out of SpotSolver)
