I'am thinking about getting a wakeboard boat but they don't look like can handle the rough water. Do they have a "V" bottom haul. I go in lake ontario so i need one that handles the choppy water well thanks
My opinion -- they're not as bad as you might think -- certainly not as smooth in rough water as a 21 - 22 ft deep V stern drive (Sea Ray, Crownline, Mariah, or somehting pretty heavy) but with some weight in the sacs and the hydraulic plate down they're pretty good. Beats the heck out of a jet boat. We take our SSV out on a big lake all the time and seem to do as well as anything else out there --- the biggest problem is you can't RIDE in rough water !
You can take up the air chair.The rough water makes little difference.
tobo57
You might want to look at the new Moomba 23ft XLV I think are the letters - has high sides - v-drive and larger for some bigger water. They carried the "V" alittle furthur down the hull.
~S~
What about the spray. have a 2012 launch 242 and passengers getting soaking wet crossing the lake. Disaster.
Any helpful tips?
The newer ones look nice. I have an '87, and it's crap on a lake with anything more than wind-chop. Worst riding boat I've owned. Gonna sell it after I fix a carb issue I've discovered. It's a shame that Supra didn't know that Ford (the engines) stands for 'Fix Or Repair Daily'.
Kevin
1993 Supra Sunsport
5.8 351 HO PCM @ 285hp / PCM (40 A) 1.23:1
Acme 422 Propeller 4 Blade 12.5 X 15.5 RH 1" Bore .105 cup
Ballast: (2) 540 lb and (2) 350 lb Straight Line Launch Pad
Wakeboard: CWB Absolute w/ Faction bindings / Surfboards: Hyperlite Coex & Broadcast
"Don't measure yourself by what you have accomplished, but by what you should have accomplished with your ability." ~John Wooden
