Does anyone here have info on these old 90’s Lowrance Depth sounders, model 3200, and the transducer? The menace to society, the raccoon, appears to have chewed through in one spot the plastic casing on the cable, but not all the way through it, just into the shielding. The display flashes zero all the time and nothing else happens. Does anyone with these old boats have this unit and do you have a manual / trouble-shooting guide? May I just cut out the bad section of the cable and solder the wires back together in the cable? Can I just get a new transducer & cable? How do I remove the sender from its epoxied spot right underneath the engine/tranny if its garbage? Or do I cut my losses here cut the cable leave the sender and mount a new one ahead of it?
