Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: Surf Weights
    Feb 2007
    Whitewater, Wi
    Default Surf Weights
    I want to compare how you all are weighting your boats for surfing. I have an 08 worlds 22 SSV. I do have the cooler and steps on the driver side. Please share your setups.
    2008 Supra 22SSV World Edition
    Sep 2009
    Cookeville, TN (between Center Hill and Dale Hollow)
    I have 750# sac in the right rear locker and 2 v-drive sacs on the seat and floor behind the the drivers seat (400# each). So, 1150#'s total with wake plate at 1/2 to 3/4 of the way up and running perfect pass around 2800-2900 rpms.
    Jun 2009
    Kamloops BC
    700 pounds in fat sacs behind drivers seat ,wake plate up 3/4 ,and 10.-10.5 mph.My rpm's are 1300-1500. you can drive straight and it willeasily will hold ya in ,even with a beer in your hand.I ride a 4'6 phase 5.
    Sep 2009
    Wake beater,
    I'm curious about your setup. Mostly about your low rpm's. Seems like I'm running 800 lbs more than you but my rpm's are much higher. What boat, prop and engine setup do u have?
    Jun 2009
    Kamloops BC
    I have a 91 mariah,21.5 ft,with a 454.I just have the stock 3 blade prop,but have really thinking about getting another ,low speed prop ,to see if i can drop those rpm's to 1000-1250.When i wakeboard at 24 mph i only run 1800-1900 rpms.So i basically burn the same gas surfin to wakeboarding,but my sets surfin are at least 20 mins.. would post pics but dont know how to resize image....
    Mar 2009
    Roseville, CA
    I have an '08 Sunsport 22V, I have the rear 750's with the front center 400 lb bags. The best formula I can find to get a surfable wake is fill the rear 750 full, and leave the front empty and get as many people back in the corner of the boat. I have never been able to get the non-goofy (port side) as good as the goofy-foot side. Even if I fill the front center 400 lb up it makes no difference in the wave for some reason, I cant figure it out.
    For Goofy side I run - 10.6, wakeplate 1/4 down
    For non-goofy (port) side I run - 11.0, wakeplate 3/4 down.
    This seems to be the best I can find right now.
    White/Charcoal, 2011 VLX
    2008 Supra 22SSV
    Jun 2009
    Kamloops BC
    Quote Originally Posted by Fman View Post
    you need to have your wakeplate up so it pushes the rear down...if you put your wake plate down it will push the bow of the boat down,..
    Mar 2008
    Orting, WA
    I have an 08 22 Launch with steps and cooler like yours.
    I moved the front 750lb bag to the left rear and put the 400lb bag that was in the back up front(thanks to a tip from Phenom) and it works great. I also have a 225lb Sumosac under the port side seat right in front of the rear v-drive locker. I have my wakeplate at neutral. Running at 10.4 to 10.6 mph depending on how many people are in the boat.
    08 Launch 22SSV
    Orting, WA
    Feb 2009
    Minneapolis, MN
    I dont have a new boat, but I agree we keep the hydrolic wake plate at the MOST 1/4 down when heavily weighted.
    Mar 2009
    You need more weight towards the back. I weight my 02 SSV like this boat (but on the port side) with the back locker full of ballast, a 750# sac on the seat and rear deck, a full GG sac in the center plus an extra 300# in the walkway. Something like 2500# total.
    If the 750# sac is only on the seat the wake is not as good.
