Originally Posted by
Okie Boarder
As many of you know, my engine is spending the winter on a pallet. Before taking it out I changed the oil, ran some fuel stabilizer in and drained as much water as possible. Should I still consider trying to get more water out? Should I spray fogging oil in the cylinders through the spark plug holes? It is going to be in the garage, but with really cold temps it can get below freezing some days in the garage and the engine is parked right near the rear garage door.
I have been told by many fogging is bad for the injectors/carburetor, I would not recommend it. Put a heat lamp in your engine compartment to keep everything warm if you are keeping your boat in the garage.
White/Charcoal, 2011 VLX
2008 Supra 22SSV
