Guys Im havin a problem finding the pump on my system. Also does anyone know if it has the screen filter to? I know the 08's had them. Just not sure if I got all the water out.
2009's won't have a filter screen like the 08's. On the intake on the bottom of the boat there is a screen built in (doesn't require any maintenance). If anything happens to get through there, those pumps are pretty strong and will chew the debris right up.
All you will need to do to winterize the 09 ballast system is disconnect your bags and drain them, run the pumps in reverse for a few seconds, the run forward to flip the veins around.
I've never heard of that being a problem with the neoprene impellers that are used in the higher end Jabsco pumps, but it's probably best just to use silicone to be safe.
Good point!
